Random lingid,pildid,gifid,mittenaljakad asjad
Mine lehele Eelmine  1, 2, 3, 4, 5, 6  Järgmine
xpr
PostitusPostitatud: Nelj. Okt. 10, 2013 10:28 am    Teema: Vasta viitega
http://en.wikipedia.org/wiki/Cadillac_Catera
ElavLegend
PostitusPostitatud: Nelj. Okt. 10, 2013 11:06 am    Teema: Vasta viitega
Õhesõnaga "Lux" omega ameerika mudel..
Soome.
Tel. +372 58115815
PostitusPostitatud: Nelj. Okt. 10, 2013 1:12 pm    Teema: Vasta viitega
Pigem see on üks huumor: http://www.cadillac-catera.com/
Kood:
Repair log
10 miles - the first problem (I kid you not) loose item replaced
4.5k miles - Engine oil pump replaced
5k - Catera is inoperative & towed to Cadillac - battery cables replaced
20k - Crankshaft harmonic balancer replaced along with ashtray and cup holder
21k - Both left & right foglight assemblies replaced along with the windshield (glass formed a stress-crack) and left headlight assembly & frt-rt window switch
22k - Both left & right foglights replaced again plus vacuum control valve, sunroof switch, passenger seat recliner motor & frt-rt door lock actuator
24k - Left headlamp & both foglights replaced again along with the A/C module, repaired lower dash vent leaking water into Catera footwell
25k - Repaired rattle under dash, shift linkage & loose rear-view mirror control contacts - lightbulbs in both foglights were replaced along with sunroof motor and switch, instrument control panel, light behind heated-seat button, shift controller, left sunvisor, seat motor, leaking weather-seal in passenger footwell and again the frt-rt door lock actuator (lock was binding and would not unlock via electric or manually, passengers would get trapped in the car!) My complaint of a "weak-battery" just above the red-zone were confronted with "above the red is within spec, nothing to worry about..."
27.5k - Catera battery is dead, car inoperative - battery jumpstarted, alternator replaced along with both foglight assemblies again and now the tailight assembly too, gas cap retainer strap broke but Cadillac decided to discontinue the straps so they simply trim off the remaining plastic with scissors, they also claim nothing is wrong with the passenger door and I am told that being trapped is not considered a serious safety issue to them because the car has other doors! It never occurred to them that not all my passengers are able-bodied enough to climb over the center console...
27.8k - That didn't last long - replaced battery. Door is still trapping people inside, ftr-rt door lock latch assembly replaced as well as driver seat recliner - Catera is returned to me with a drivers seat that is now visibly cocked-and-bent and a passenger and now the door that won't open from the outside door handle. They take another shot at repairing both items while I wait another 2-hours at the Cadillac dealer.
27.9k - Side mirror gets shattered while vehicle is parked near a baseball field Cadillac dealer charged me $535 to replace damaged drivers side mirror.
29k - Replaced seat memory system, seat cushion and seat frame
29.6k - Replaced seat frame, re-calibrated seat-recline electronics, repaired black-grease coming out of shifter knob, while doing the repairs they damaged the seat leather with a tool, repaired while I waited a few more hours.
29.9k - Horn bracket corroded and the horn fell off under the car (replaced), replaced seat cushion
30k - front tires worn so far that internal-belts have become visible on the bald tire surface, replaced + alignment = $400
33.6k - Catera completely dies while I am 130-miles away from home - Cadillac towing service brings vehicle to Condor Cadillac who diagnosed a seized timing belt and all valves are bent - replaces the entire engine, 3-weeks later I drive 130miles to pick the car back up only to find 400-miles added to the odometer! and the following issues that lead me to drive 130miles back home in the loaner car:
34k - A/C and traction control don't work, drivers window only goes full-open or closed (won't stop in the middle), 10-days later they replaced A/C "plate tube", knock sensor wire connection and a "burnt-out" window switch and I drive another 130miles to pick up the car
34.1k - Check engine light goes on after 100miles of driving, not even home yet...
35k - Replaced cracked air hoses (yes, on an engine with only 900miles on it) and reported a missing engine mounting bracket and misrouted wiring harnesses but refused to fix Condor Cadillac's poor workmanship. Somehow North Bay Cadillac cannot replicate that the check engine light is on?! They must have hit the reset function when they plugged in the OBDII...
35.1k - Catera is inoperative - roadside assistance replaces battery
36k - Drivers-door won't open more than a few inches! Replaced door-hinge reinforcement bracket
36.1k - Front seat heaters replaced with inferior units, roughly 25% heating temperature of the original untis, also adjusted misaligned windshield wiper arms and replaced fuel filler cap, remote transmitter and lt-rear door panel trim
36.4k - Drivers-door panel trim separating, replaced along with door handle-trim and the heated seat elements that also stopped working - check engine light on, North Bay Cadillac refused to fix under warranty claiming the fault of workmanship by Condor Cadillac which is 130miles away, what should the customer do about it?! Cadillac customer-care towing service chose to tow the totally-inoperative Catera to the closest dealer which was Condor.
37k - Frt-rt headlight inoperative, replaced
37.2k - Replaced door lock plastic facade (it fell off), replaced keyless remote transmitter (inoperative)
39k - Car Cash offers to buy my Cadillac Catera for $6,500, price new after taxes $39,000 - Catera depreciates $0.83 every mile driven!
42k - Catera is inoperative yet again - new battery installed roadside
42.5k - Windshield wiper motor replaced- before this the Cadillac dealer insisted that the slow wipers were due to old blades and replaced them charging me $55 for the pair of wiper blades, "tightened" the gas cap in response to check engine light being on, replaced timing belt, tensioner, pulley and coolant
43k - Wheel alignment, check engine light is on, brake rotors severly warped (replaced), replaced seat-heater switches (apparently they pried them out with a screwdriver as it left marks in the plastic bezel), rt license plate bulb replaced along with high-mount breaklight lamp bulb and light behind traction-control button
43.2k - replaced rear tires - $300
44k - high-mount breaklight assembly replaced but they installed a supposedly-new unit with a crack in the plastic, replaced engine wiring due to check engine light on, replaced drivers side-mirror - charged $540
45k - water entered through the crack in the high-mount breaklight and shorted it, replaced it with a "real" new unit
45.5k - Front brake pads and rotors replaced - charged me $400
47k - HVAC stops working - repaired loose electrical connection - charged me $100
49.1k - No air coming out of HVAC system - no defroster means no vision driving when it is humid & raining - replaced fuse
49.2k - Still no air coming out of HVAC - replaced blower motor and fuses - charged me $450
49.9k - Still no air coming out of HVAC - replaced fuse for blower motor - charged me $70
50.1k - Still no air coming out of HVAC - replaced fuses again and a $200-resistor for the blower motor, while repairing this they bent the passenger-airbag cover, so replaced that too - charged me $270 with labor
50.2k - Still no air coming from the HVAC and now the glove box rattles, rerouted the HAVC control assembly & electric harnesses and reinstalled the glove box
52.2k - A/C & defroster blows room-temp, wire harness mysteriously torn out of compressor?! - went to a local garage and had compressor replaced as well as front sway bar links ($60 x2 + $40 for 30-minutes labor - Cadillac dealer misdiagnosed the sway bar issue as either ball joints or tie rods, a $600+ job)
52.7k - Replaced idler arm - this is my last trip to the Cadillac dealer and from here on the issue frequency and severity is dramatically reduced. What is the likelyhood that this is just a coincidence?
54k - Add freon to A/C
60k - Wheel alignment and 4-new tires
65k - Leaking tire valve replaced, all 4-sets of brakes/rotors replaced
68k - driver-memory system stops working, pressing any of the memory-preset buttons while driving makes both outside mirrors point downward which is quite scary while in heavy highway-traffic (yes, I tried to reset the memory settings only about a hundred times, it is indeed broken)
71k - Flat tire - upon tire removal the rear hub rotates closing off the bolt threads, AAA comes to my aid, releases the parking brake to be able to adjust the hub and then the car falls of the jack and flattens the 3-ton jack like a pancake.
71.5k - Car frequently stalls while moving resulting in sudden loss of power-brakes and power-stearing - replaced mass air flow MAF-sensor
72k - Excessive engine squeal, replaced serpentine belt and belt tensioner pulley
72.1k - No brakes! - leak in the driverside-rear brake line repaired and both rear brakes bled
73k - Driving is now an odor-full experience, alternating between the sweet smell of steaming coolant and the horrific stench of burning oil - neither of  two different repair shops could find any oil or coolant leaks
73.5k - Driving over bumps makes the car jolt violently either left or right (unpredictable direction), it is now a challenge to keep this car within its own lane - lower control arm bushings completely worn out (no rubber left at all, just a gap where they used to be), did not get a chance to repair this before the final blow-
74k - Huge amounts of steam began shooting out of what appears to be a seam-separation in the radiator and the car overheats and stalls frequently, upon adding more coolant after this incident it is discovered that both the coolant reservoir and the oil-fill tube are filled with a mayonnaise-looking goop indicating a blown head-gasket. Compound that with a failed radiator + no control-arm bushings and this is beyond reasonable repair.
PostitusPostitatud: Nelj. Okt. 10, 2013 11:06 pm    Teema: Vasta viitega
Ja kellele see naljakas tundub,siis jutt käib Opel Omega B st,millel teine esi-tagaots :D
PostitusPostitatud: Nelj. Okt. 10, 2013 11:25 pm    Teema: Vasta viitega
ja teine el.süsteem ka. Opelit meenutavadki aind plekid ja mootor. veermik on ka natuke "margikohasem", rattalaagrid ja puksid on erinevad. igati ok masin muidu. tartus on ka üks, käis remondis. hammasrihma vahetus on kebernaks, muud pole midagi hullu.
aga see huumori list, ma saan samasuguse koostada iga päev mõne audi või Passati all, seega pole eriline näitaja. lihtsalt konkreetne vend on saanud praagi... üldiselt on "meeriklane" ikka vähe etem. töökaaslase pontiaci buss on aastast 94 ja kõik lisad töötavad, k.a elektriline küljeuks. uus 2013.a Alhambra el. küljeuksed läksid pekki poole aastaga, kuskilt jookseb vesi laepolstri peale, 40 000km jooksul on salong nagisema hakanud, rooli nahk jumala kulunud, DSG kasti kahemassiline hooratas katki, xenon ei tööta lambist, pidurisadulate el. mootorid oksüdeerunud.. nimekiri on pikem ja seda kõike pea aasta vanusel autol.
PostitusPostitatud: Kolm. Okt. 16, 2013 1:00 pm    Teema: Vasta viitega
BMW AK47
2020-XXXX 9. Skoda Superb Lauren&Klement AWD 2018
2017-2020 8. Volvo V60 AWD D5 Summum
2015-2017 7. Audi S5 Sportback Stage 2
2014-2015 6. Volvo XC60 AWD D5 Summum
2012-2013 5. Audi A4 B8 Avant
2010-2012 4. BMW E46 328i Touring
2008-2010 3. Ford Probe
2007-2007 2. VW Golf mk1 '81
2006-2006 1. VAZ 2106 '77
2017-XXXX 4. Ducati Monster S4R
2015-2016 3. Ducati Monster S4R
2015-2016 2. Dnepr MT-10 Cafe Racer
2014-2015 1. Suzuki GSR600
PostitusPostitatud: Teis. Nov. 05, 2013 6:21 pm    Teema: Vasta viitega
http://www.youtube.com/watch?v=OT8Eh7BBqOQ#t=67
PostitusPostitatud: Reede. Nov. 08, 2013 12:30 am    Teema: Vasta viitega
http://jaguarshowroom.com/post/57173718833/the-c-x75-has-a-combined-power-output-in-excess-of
The C-X75 has a combined power output in excess of 850bhp and 1000Nm of torque, thanks to its state-of-the-art, Formula 1-inspired, 1.6-litre dual-boosted (turbocharged and supercharged) four-cylinder powerplant which generates 502 bhp at 10,000 rpm.
PostitusPostitatud: Kolm. Nov. 20, 2013 3:14 pm    Teema: Vasta viitega
http://www.youtube.com/watch?v=-Z7UnO66q9w
Psycho
PostitusPostitatud: Kolm. Nov. 20, 2013 6:08 pm    Teema: Vasta viitega
Mis komme sa sõid? :D
PostitusPostitatud: Kolm. Nov. 20, 2013 9:35 pm    Teema: Vasta viitega
Mina näitasin talle seda
PostitusPostitatud: Nelj. Nov. 21, 2013 11:51 am    Teema: Vasta viitega
jah ja tal tabletid võtmata mitu päeva juba
PostitusPostitatud: Reede. Nov. 22, 2013 4:28 pm    Teema: Vasta viitega
taunod
PostitusPostitatud: Laup. Nov. 23, 2013 12:44 am    Teema: Vasta viitega
http://www.thewire.com/entertainment/2013/09/zach-galifianakis-says-everything-adults-have-been-wanting-say-justin-bieber/69907/#disqus_thread
PostitusPostitatud: Laup. Dets. 21, 2013 12:40 am    Teema: Vasta viitega
http://www.youtube.com/watch?v=h0bpDdzlWF0
PostitusPostitatud: Reede. Jan. 10, 2014 1:56 am    Teema: Vasta viitega
http://www.build-threads.com/build-threads/ferrari-f40-lm-restoration/
taunod
PostitusPostitatud: Kolm. Jan. 15, 2014 9:51 pm    Teema: Vasta viitega
https://www.facebook.com/photo.php?v=364941816945934
PostitusPostitatud: Esm. Jan. 20, 2014 6:21 pm    Teema: Vasta viitega
Eestimaist road-rage'i:
http://www.youtube.com/watch?v=A_u1VE9-D-0
PostitusPostitatud: Esm. Jan. 20, 2014 6:26 pm    Teema: Vasta viitega
Eriti hea, tahaks teada, mis peale väljasõitu sai .D
PostitusPostitatud: Teis. Jan. 21, 2014 3:16 pm    Teema: Vasta viitega
Oi jah, inimestel on ikka väga igav ja üleval kupli sees valitseb tühjus.
Nägin ise ka ükspäev mingit audi 80-t, mis sõitis paremas reas (isegi veits aeglasemalt kui lubatud - rooli taga mingi noor kiilakas tatt). Vasakus reas sõitis mingi ford mahtuniversaal, sama kiirusega nagu audi. Ühel hetkel kui vasak rida hakkas lõppema, mõtles fordi mees, et kiirendab veits ja sõidab venivast audist mööda. Aga oh imet - ajukääbikust audimehele vist ei mahtunud hinge, et mingi fordikärakas tast mööda hakkab pressima ning litsus ka oma akseleraatorpedaali põhja.
Mul tekib sellistes olukordades lihtsalt küsimus - miks?
Seina äärde paras sellised panna.
PostitusPostitatud: Teis. Jan. 21, 2014 5:02 pm    Teema: Vasta viitega
Tln-Trt maantee 4-realisel on seda imho iga jumala kord, kus 2 idiooti venivad sama kiirusega kõrvuti.
Ükskord otsustasin peale mõnekilomeetrist uimerdamist ühe jobu taga tuledega vilgutama hakata. Kulus omajagu kui tüüp vasakus reas kiirendama hakkas aga paremale siiski ei reastunud vaid sõitis aeglaselt endiselt vasakus reas edasi. Siis otsustasin, et möödun temast ise parempoolsest reast. Kui mina tema kõrvale jõudsin, hakkas tema ka sinna reastuma ja jäid vaid sentimeetrid minu ja tema auto vahele ning olukorra päästmiseks pidin mina äkkpidurdama. Tema ei saanud arugi mis ümberringi toimub, minu signaali laskmine teda ümber otsustama ei pannud - siht oli ikka samma ritta tulla.
Muuseas ei olnud naine roolis, täitsa 40-50'dates mees.
Aga overall - iga reede ja pühapäev mis ma tln-trt maanteed sõitnud olen, näeb ikka hämmastavalt palju sitahädasi, kellel tuleks load ära võtta. Kui rekkast ka möödasõitu teha ei julge siis nahui kuidas sa üldse liikluses hakkama saad... nii tore on ju 10-15'st autokolonnist möödasõite teha, kes rekka taha varieeruva kiirusega töllerdama on jäänud ja siis iga kiiruskaamera ees -20km/h piirkiirusest maha võtta plaanivad.
Kui liiklusest kõrvaldada need, kes 2-realisel sõidavad kõrvuti ning need, kes rekkadest kunagi möödasõite ei tee, oleks elu teedel päris lilleline.
PostitusPostitatud: Teis. Jan. 21, 2014 7:22 pm    Teema: Vasta viitega
Mina mõistan millest jutt
PostitusPostitatud: Teis. Jan. 21, 2014 10:19 pm    Teema: Vasta viitega
Kahju, et siin LIKE nuppu pole postituste juures, kasutaksin seda kohe Alani jutu juures :D
PostitusPostitatud: Kolm. Jan. 22, 2014 3:16 pm    Teema: Vasta viitega
Alan kirjutas:
Bmw vaatenurk
http://youtu.be/aYI1nDlbryk
PostitusPostitatud: Kolm. Jan. 22, 2014 3:51 pm    Teema: Vasta viitega
teet001 kirjutas:
Alan kirjutas:
Bmw vaatenurk
Voh, kohe teine pilt asjast...
Päris huvitav kokkusattumus, et mõlemal osapoolel dashcam :)
PostitusPostitatud: Nelj. Jan. 23, 2014 11:17 pm    Teema: Vasta viitega
Huvitav jah, see volkswageni video jäi nagu painama ilma lisainfota.
Samas, huvitav, mis veel edasi sai?
Tõmbab siis sae ka käima: kumb valesti käitus?
PostitusPostitatud: Reede. Jan. 24, 2014 12:20 am    Teema: Vasta viitega
vw käitus imo valesti ja bmw juht reageeris kaugelt üle
ehk 2 valet venda said kokku mis päädis õnnetusega. Mingi noor naga oli vw roolis olnud, politsei kohale ei tulnud. Tean,sest bmw-ga sõitis üks vana töökaaslane...
Heigo72
PostitusPostitatud: Reede. Jan. 24, 2014 6:26 pm    Teema: Vasta viitega
Siin mõnes teises juturingkonnas räägitakse , et vennad olevat olnud omavahel head tuttavad . Ja tahtnud nagu alati, teha huvitavat videot aga kukkus välja sitasti. Nüüd Pollar pidavat ka neil seljas elama.
Minul kiiret ei ole !!! Tark ei torma.
PostitusPostitatud: Esm. Jan. 27, 2014 9:50 pm    Teema: Vasta viitega
Purjuspeaga sõitmise ad
http://www.youtube.com/watch?feature=player_embedded&v=wq1tXcpOGus
PostitusPostitatud: Nelj. Veeb. 27, 2014 12:15 am    Teema: Vasta viitega
http://bashny.net/t/en/101219
zil viper
PostitusPostitatud: Nelj. Märts 06, 2014 10:55 am    Teema: Vasta viitega
http://gmersu.blogspot.com/
Nii, ülesanne siis selline, et originaal G460 fikseeruvad lülitid asendada W203 plokis asuvate mitte fikseeruvate lülititega ning kellade plokk asendada W203 kellade plokiga. Kuna originaalis kogu W203 nende plokkide omavaheline ühendus käib CAN -is, mida aga ma läbi ei hammustanud, selle põlvkonna G aga ei osanud veel uneski CAN -i näha, otsustasin nendesse W203 plokkidesse ja mujale teha oma kontrollerid. Lülitid ning ledid ühendada originaal elektroonika otsast lahti ja ühendada oma kontrolleri külge. Oma kontrollerid ühendan omavahel samuti CAN võrguga, mis aga ei ole või on :D ühenduses mõningate allesjäänud originaal can osadega. Oma kontrollerid hakkavad baseeruma Atmeli toodangus olevatel AVR mikrokontrolleritel nagu Atmega8, Atmega16 jne.
G originaal elektri osasid nagu, tulede ja suundade jne lülitamine jääb samaks, nendest lülitamistest võetakse ainult sisesdinfot.
tasub nats vaadata
PostitusPostitatud: Nelj. Märts 06, 2014 11:26 am    Teema: Vasta viitega
Vot multitalent.
jankii
PostitusPostitatud: Püh. Märts 09, 2014 10:29 pm    Teema: Vasta viitega
Tõsine tegemine müts maha
PostitusPostitatud: Esm. Märts 10, 2014 1:03 am    Teema: Vasta viitega
Hobiautondusest.
http://www.tqhq.ee/forum/viewtopic.php?tid=41969&page=3
See on raske - aga see positiivne meeleolu kaalub kõik üles. Eriti Alan on mõttetute raharaiskajatega võiks õppust võtta imho. Raha on ,aga auto on jama tegelt ;) Offence !
PostitusPostitatud: Esm. Märts 10, 2014 1:17 am    Teema: Vasta viitega
Hobiautondusest.
Olen nõus igava auto osas... Ei ole tekkinud võimalust ebapraktilise auto omamiseks. Unistused on suured, äkki jõuab kunagi neid otsast täitma hakata.
Audist on plaan see aasta lahti saada, et asendada järgmise igava igapäevasõidukiga.
PostitusPostitatud: Esm. Märts 10, 2014 9:44 am    Teema: Vasta viitega
Tallinnas elades ausalt öeldes sõidaks vist mingi igava maasturiga,mis plaanis osta on siis ?
PostitusPostitatud: Esm. Märts 10, 2014 11:47 am    Teema: Vasta viitega
Justnimelt igavat maasturit :D
PostitusPostitatud: Püh. Märts 23, 2014 10:17 pm    Teema: Vasta viitega
Pikk teema, aga tasub lehitsemist :)
http://ruffrodders.com/forum/showthread.php?t=59749
sama tüübi teine projekt: http://ruffrodders.com/forum/showthread.php?t=65740
taunod
PostitusPostitatud: Teis. Apr. 01, 2014 10:44 pm    Teema: Vasta viitega
Esimeseks aprilliks väga ei sobi:
https://www.youtube.com/watch?v=BFCOy9KXX4I
PostitusPostitatud: Kolm. Apr. 02, 2014 11:18 pm    Teema: Vasta viitega
http://vimeo.com/90162460
ElavLegend
PostitusPostitatud: Püh. Apr. 06, 2014 7:44 pm    Teema: Vasta viitega
Sai sellist asjandust nähtud...
https://www.facebook.com/photo.php?fbid=738165036203635&set=a.348848225135320.81928.100000304359110&type=1&theater
Soome.
Tel. +372 58115815
PostitusPostitatud: Püh. Apr. 27, 2014 3:44 pm    Teema: Vasta viitega
http://www.jalopyjournal.com/forum/showthread.php?t=800077
ElavLegend
PostitusPostitatud: Püh. Apr. 27, 2014 3:49 pm    Teema: Vasta viitega
Huvitav,kus on siin tagaklaasi soojendus
http://www.auto24.ee/used/1728725
Soome.
Tel. +372 58115815
PostitusPostitatud: Esm. Apr. 28, 2014 7:54 pm    Teema: Vasta viitega
rear window defroggeri sõna leidsin veel mitmest kuulutusest, ja põhimõtteliselt ei takista miskit sellel seal olemast ka ju ?
taga ju klaas täiesti olemas.
PostitusPostitatud: Teis. Mai 20, 2014 10:26 pm    Teema: Vasta viitega
Tund vaatamist ja head muusikat
https://www.youtube.com/watch?v=GXQdE8oyIhA&list=UUaFAiK8rnhU1y4bNfQhSpsg
PostitusPostitatud: Püh. Juun. 01, 2014 11:20 pm    Teema: Vasta viitega
https://www.youtube.com/watch?v=ZcjpXbMiCtg
vaadake lõpuni ja küsige endalt,kuhu on pandud see 13 .... :) ?
PostitusPostitatud: Esm. Juun. 09, 2014 12:03 pm    Teema: Vasta viitega
löööööööt.
Kehtivad ülevaatused: Liiklemiskeeld. Sõidukil puudub kehtiv korraline ülevaatus.
PostitusPostitatud: Esm. Juun. 09, 2014 4:27 pm    Teema: Vasta viitega
see keeld tuli vast peale politseid peale ikka ;)
kas kuskilt selle auto kohta pikemalt ka lugeda on ?
ElavLegend
PostitusPostitatud: Esm. Juun. 09, 2014 9:41 pm    Teema: Vasta viitega
http://www.metro.fi/uutiset/a1387804542097
Valus pauk...
Soome.
Tel. +372 58115815
PostitusPostitatud: Reede. Juun. 13, 2014 8:34 pm    Teema: Vasta viitega
Kui ikka reedel kodus siis mängi sellega
http://img0.liveinternet.ru/images/attach/c/5/3970/3970473_sprite198.swf
Lehekülg 5, lehekülgi kokku 6
Car Club Viljandi © 2020
