kas ´kellegil oleks pakkuda võimu mullle 550 suppari taha
Tere!
Mul oleks siis sul sinna pakkuda : Infinity 1600a hind: 4800.- ,
SPL FX2-600 hind: 2500.- ,
Alpine MRP-M650 hind: 4700.- ja
MTX Audio TA5601 Thunder 5601 hind: 4774.-
# mono car subwoofer amplifier (Class D) # RMS Power Ratings: * 300 watts x 1 @ 4 ohms * 600 watts x 1 @ 2 ohms # Wired EBC Remote Subwoofer Bass Level Control Included # Fan cooling with XTC thermal regulation technology # Prizm EFX customizable lighting accents # Variable remote bass boost/cut (plus or minus 12 dB, variable 30-80 Hz) # Variable low-pass filter (40-200 Hz at 24 dB per octave) # Selectable subsonic filter (12 dB at 30 Hz) # MOSFET power supply and output stage # CEA-2006 compliant # Speaker-level inputs with Smart Engage # Dimensions: 16-11/16\\\" L x 9-5/8\\\" W x 2-1/2\\\" H
Alpine MRP-M650
# Class D mono subwoofer car amplifier # 400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms) # Variable low-pass filter (50-200 Hz, 24 dB/octave) # Tuned Bass EQ (0-12 dB bass boost at 50 Hz) # Subsonic filter (24 dB at 15 Hz) # MOSFET power supply # CEA-2006 compliant # STAR Topology (minimizes internal noise and prevents ground interference) # Speaker- and preamp-level inputs # Gold-plated screw terminals # Fuse rating: 30A x 2 # 8-gauge amp wiring kit with 60-amp fuse recommended — wiring and hardware not included with amplifier # 12-13/16\\\"W x 2-3/8\\\"H x 9-9/16\\\"D
SPL FX2-600
600W Max, FX Series 2-Channel Amplifier • 600W Max, FX Series 2-Channel Amplifier • 4 ohms: 95 watts x 2 chan • 2 ohms: 120 watts x 2 chan • Bridged, @ 4 ohms: 240 watts x 1 chan • S/N Ratio: 98dB •THD: 0.02%
Infinity 1600a
894W Max, Reference Series Class D Monoblock Amplifier (REF1600A) Reference Series Class D Monoblock Amplifier • 400W x 1 chan. @ 4 ohms • 600W x 1 chan. @ 2 ohms • MOSFET power supply • Gold-plated preamp RCA outputs • Wired remote bass level control included
