Müüa odavalt 200sx s13,s14, 300zx,JDM silvia juppe!!!
Uus teema   Vasta teemale    Car Club Viljandi -> Sõidukid/varuosad
skylineGTT
PostitusPostitatud: Teis. Nov. 04, 2008 9:53 am    Teema: Müüa odavalt 200sx s13,s14, 300zx,JDM silvia juppe!!! Vasta viitega
Nissan 200SX S13
Doors with window and lifter and door cards – 25Eur;
Side mirror - 12Eur;
Headlight – 18Eur;
Prefacelift drivers seat – 15Eur;
Fenders plastic covers kit – 12Eur;
Engine parts:
CA18DET exhaust cam good condition with CAS tooth – 30Eur;
CA18DET engine block blokas – 30Eur;
CA18DET carter – 15Eur;
CA18DET ignition coils – 10Eur;
CA18DET arternator – 10Eur;
CA18DET intake manifold with injectors 4x 370cc also fits to Honda – 45Eur;
CA18DET Power steering pump – 12Eur;
CA18DET Cooling radiator – 15Eur;
Also have a lot of brake, suspension and other parts.
Nissan 200SX S14/a
S14/a LHD -> RHD steering wheel removal full kit(all needed parts including small details) – 930Eur;
S14a Tail lights kit 3pcs – 130Eur;
S14a Rear trunk with stop light – 30Eur;
S14a Front bumper – 40Eur;
S14a Hood with defect repailable – 90Eur;
S14a turn signal – 25Eur;
S14a Fog lights – 30Eur;
S14a Europien Headlight – 130Eur;
S14a Front brakes kit (calipers, pads, disks) – 75Eur;
S14a Rear brakes kit (calipers, disks) – 35Eur;
S14a Airbag for steering wheel 26Eur;
S14a Manual Gearbox – 280Eur(also have all parts for swap AT->MT);
S14a Air Flow Meter MAF – 30Eur;
S14a Stock wheels with tyres – 100Eur;
S14a Fuel pump – 20Eur;
S14a Automatic Gearbox with hydro coupling – 45Eur;
S14a drive shaft – 15Eur;
S14/a Fenders plastic covers kit – 20Eur;
S14/a 5 lug kit into S13 front/rear – 75Eur;
S14/a Rear sub frame with good bushings – 35Eur;
S14/a Front lower arms – 25Eur (upgrade into S13 because it is 7mm longer then S13, it will increase front camber);
S14/a Front shocks – 25Eur;
S14/a Rear shocks – 30Eur;
S14/a Airbag under dash – 20Eur;
S14/a Rear bumper – 30Eur;
S14/a Full lether interior – 70Eur also fits to S13 and other Nissan models
S14/a Vynil interior – 35Eur;
S14/a Doors with window and lifter – 55Eur;
S14/a Miror – 20Eur;
S14 Europian front Headlights 75Eur;
S14 Grill – 20Eur;
S14 Hood 60Eur;
S14 Fenders 40Eur;
S14 Turn signals 12Eur;
S14 Fog lights Priesrukiniai – 30Eur;
S14 Corner lights – 12Eur;
S14 Front bumper with spliter – 35Eur;
S14 Tail lights 15Eur;
S14 Airbag for steering wheel – 20Eur;
S14 Driveshaft – 15Eur;
S14 Air Flow meter MAF - 35Eur;
JDM SIlvia OEM grill – 30Eur;
JDM Silvia Klimatronic with all sensors and all harness and conectors – 75Eur;
JDM Silvia OEM rear bumper spats – 25Eur;
JDM Silvia OEM folding mirrors – 60Eur;
JDM Silvia OEM rear glass without rear wiper hole – 45Eur;
Engine parts:
SR20DET Alternator – 15Eur;
SR20DET starter – 12Eur;
SR20DET injectors 4x 370cc – 35Eur;
SR20DET coil packs – 25Eur;
SR20DET Thermo coupling – 15Eur;
SR20DE engine block from Silvia S14 RWD perfect condition (could be remade as DET block) – 45Eur;
SR20DET carter 2 parts – 20Eur;
SR20DET Cam Angle Sensor CAS – 25Eur;
SR20DET Power steering pump – 15Eur;
SR20DET Cooling radiator – 45Eur;
SR20DET Cooling panel – 30Eur;
Nissan 300ZX Z32 VG30DETT
Manual gearbox kit for swapping from AT->MT (full kit all needed parts including small details) – 930Eur;
Automatic Gearbox with hydro coupling – 90Eur;
Diff V-LSD 100Eur;
R16 stock wheels staggered setup with tires – 150Eur;
Fuel pump 255Lph for max 700HP+ - 60Eur (performance upgrade for S13, S14/a);
Hood Aluminum – 120Eur;
Headlights – 45Eur;
Headlights with Xenon – 70Eur;
Fender – 45Eur;
Roof window – 35Eur;
Doors – 30Eur
Door window – 30Eur;
Mirrors – 30Eur
Tail lights kit 3pcs – 120Eur;
Rear bumper – 45Eur;
Rear trunk with window and spoiler – 45Eur;
Steering wheels – 25Eur;
Front shocks with springs – 35Eur;
Rear shocks with springs – 45Eur;
Engine’s VG30DETT parts:
Starter – 30Eur
Alternator – 30Eur
Thermo coupling – 25Eur;
Ignition coils – 20Eur;
Injectors 6x 370cc – 60Eur
Cam Angle sensor CAS – 45Eur
Air Flow Meter MAF – 90Eur
Intake manifolds with throttles and TPS – 45Eur
Power steering pump – 30Eur
Almost brand new cooling radiator KOYO – 70Eur;
JUPID ASUVAD LEEDUS. KEL HUVI SIIS VÕTKU ÜHENDUST! (henri.freiberg@hotmail.com)
Uus teema   Vasta teemale    Car Club Viljandi -> Sõidukid/varuosad Kõik ajad on GMT + 3 Tundi
