Olemas tokumendid , võibolla ka kehtiv garantii , asjad korra stendis olnud , autos kasutatud pole.
Midbass;
Signat H96
6x9 inch component midwoofer, 80W RMS power handling, 88,5dB/w/m sensitivity, 40Hz-5kHz frequency response. Injected carbon polypropylene cone,...
MP3 makk
panasonic cq c1311ne
TEKNISKE SPECIFIKATIONER
Amplifer Section
Output Power (Max.) 50W x 4
Output Power (DIN 45324 at 14.4V) 22W x 4
Speaker Impedance 4-8 ohms
Preamp Out Level/Impedance (CD Changer Mode) 2,5V/200 ohms
Subwoofer Output Level/Impedance -
LPF Frequency -
HPF Frequency -
CD Player Section
Frequency Response ((±1dB) 20Hz-20kHz
S/N Ratio (2.5V) 96dB (2,5V)
THD (1kHz) 0.01%
Channel Separation (1kHz) (Preout) 75dB (2,5V)
Tuner Section
Frequency Range FM:87,5MHz-108MHzMW:531kHz-1602kHzLW:153kHz-279kHz
S/N Ratio (mono) 62dB
General
Power Source (DC) 12V (11V-16V)
Input Level/Impedance -
Current Consumption Less than 2,5A(0,5W)
Dimensions 178 x 50 x 160mm
2x toitejuhtmed ja 2x kaitsme kompl, 2x olemas ka RCA kaabel .
Subwoofer; Bazooka EL andmeid kahjuks ei tea aga kõlar tndus seake väike olevat 6" ehk
andmed sealt http://www.usblaster.com/index.php/9,hid--128,sid--6,sg2id--9,artId--214
Model USB 3370
Power RMS 2 4x200W
Power RMS 4 2x100W
Power bridged 2 RMS 2x 400W
Input sensitivity 200mV - 4V
Technology Mosfet Power
S/N ratio 100dB
Frequency range 20Hz - 20kHz
THD <
Channel separation 60dB
2 stable Yes
Damping factor 100
Low pass filter 30 - 300Hz
High pass filter 30 - 300Hz
Dimensions 237x68x335mm
Signat high/low power impedance adaptor 2x30w- kui makil puudu võimu väljundid siis nendega saama hakkama. 2 tk neid üks natuke kasutatud teine karbis .
53324489 kui kellegi midagi seismas ehk saame kaupa teha _________________ unistused pildil
