3-way 3-speaker System
200mm Pearl Mica Injection P.P.Cone Woofer
55mm Silver Laminate Cone
Image Enhancer (Patent of KENWOOD since 1987)
350W Peak Input Power
Speaker Features
Speaker System 3-way 3-speaker System
Speaker Type Coaxial
Peak Input Power 350W
Rated Input Power 90W
Speaker Size 200mm
Speaker Cone Design Pearl Mica Injection P.P.Cone (silver)
Magnet Type Ferrit
Terminals Slide type
Installation Capabillity Door/Rear Deck
Image Enhancer (Patent of KENWOOD since 1987) Yes
Maximum Input Power 180W
Woofer Cone material Pearl Mica P.P.cone
Speaker Basket Steel
Speaker Surround Butyl Rubber
Sensitivity 92dB/W/m
Frequency Response 25Hz ~ 30000Hz
Speaker Impedance 4Ω
Dimensions (W x H x D) 245.2 x 245.2 x 245.2mm
Mounting Depth 90mm
Mouting Hole Diameter Ø 179mm
Speaker Weight with Grille (pc.) 2370gr
Speaker Weight w/o Grille (pc.) 2100gr
Gross Weight 5500gr
Weight of Magnet 500gr
