Evil 9 Vana tuttav
Liitunud: 14 Märts 2008 Postitusi: 465 Asukoht: Viljandi
Postitatud: Esm. Märts 22, 2010 10:21 pm Teema: MÜÜDUD! Blaupunkt Calgary MP35 |
Müüa Blaupunkt Calgary MP35 raadio/cd/mp3 mängija. Kõik toimib, mõned kriimud paneelil. Komplektis kõik mis ostes (kasutusjuhend, ISO pistikud, raam, eemaldamiseks vajalikud rauad)
Lisainfo:
Blaupunkt Calgary MP35 CD receiver key features
Easy to use and easy to install RDS radio CD / MP3 receiver.
Black removable front panel, large white display and red button illumination.
Powerful 4 x 45W amplifier with X-BASS loudness and comprehensive tone control.
Easily upgradeable with connections for remote control, CD changer, external amplifiers and personal hi-fi auxiliary input.
Radio tuner features:
LW / MW / FM waveband coverage. 30 stations can be preset
RDS-AF (alternate frequency) feature inaudibly retunes the receiver to the best available signal for the station that is currently set
Travelstore automatically stores the six most powerful radio stations transmitting locally in the FM memory bank
TA (traffic announcement) will switch station for the duration of a traffic report. The original station is restored at the end of the report. Tone, balance and volume of traffic announcements can be independently set.
PTY-EON (programme type) information displays and allows selection of similar types of programme (news, pop, classics, sport etc.)
Preset scan will play all receivable stations for a period (can be adjusted between 5 and 30 seconds)
Switchable hi-cut filter improves reception of weak FM stations by reducing treble
CD features:
Will play standard audio CDs and CD-R&R/W discs
Fast searching, random play, pause, track scan and track repeat functions
Anti-shock memory temporarily caches playback data so if a bump in the road sends the laser off track, playback sound will not be affected
CD text information (if present on disc) can scroll across display if selected
Display can be set to show track number & clock time or track number & playing time
Compatible Blaupunkt aftermarket CD changers can be connected
MP3 features:
Up to 999 MP3 tracks can be handled. Tracks can be grouped into a maximum of up to 252 directories. Directories can be nested into an unlimited number of levels
MP3 decoder will support variable bit rates between 8 kbps and 320 kbps
Both directory and file names can be displayed. Unit will also display ID-3 tag (version 1) information
Display can be configured to always scroll directory / file / artist / track / album name once, every time a track is selected
Fast searching, random play, track scan and track repeat functions
Amplifier features:
4 x 45W max power amplifier (4 x 25W RMS). Separate adjustments for treble, bass, fader and balance
Source-specific sound adjustment. Bass & treble settings can be different for each sound input source.
Equaliser is preset with settings suited to either POP, ROCK, or CLASSIC music styles
X-BASS loudness sound enhancement for low level listening. Programmable in four stages for a full sound at low volumes (each audio source can have its own level setting)
Power on and mute volume can be independently set
Four channel (3.0V) preamp output for connecting external amplifiers (requires accessory cable)
Other features:
Blaupunkt compatible infra-red remote controls can be added as an optional accessory. Unit can be linked to many makes of factory-fitted remote controls with an additional adaptor
Mute facility can be manually selected, or automatically activated by hands free phone call. Mute volume level is adjustable
Auxiliary input facility to connect external walkman MP3 device etc. (requires accessory cable) (Not available if CD changer is connected)
Timer allows one hour of use with ignition switched off, to protect vehicle's battery
Clock display (12/24hour) can be selected. Clock display can show continuously when unit is switched off, but ignition on
Red control button illumination
What's in the box?
Calgary MP35 radio CD receiver with mounting sleeve
Radio removal keys
Rubber rear support
Front panel retaining screw
Operating and installation instruction booklet
Anti-theft insurance registration card
Hinnaks: 950.-
Asub: Viljandis
Kontakt U2U või 5564 8558
Viimati muutis seda Evil 9 (Laup. Juun. 19, 2010 12:41 am). Kokku muudetud 2 korda |
Evil 9 Vana tuttav
Postitatud: Püh. Apr. 18, 2010 10:23 am Teema: |
| UUS HIND: 800.- |
Evil 9 Vana tuttav
Postitatud: Nelj. Juun. 10, 2010 9:54 pm Teema: |
Auto24 juba ammu oli 700.-
Pole kellegi huvi? Kõik töötab. Seisab ikka veel niisama kapi otsas. |
Evil 9 Vana tuttav
Postitatud: Laup. Juun. 19, 2010 12:41 am Teema: |
| LUKKU, asi uue omaniku saanud! |
