M: Innovate LC-1 Wideband o2 With Db Blue/Red Gauge
Uus teema   Vasta teemale    Car Club Viljandi -> Sõidukid/varuosad
Markm
PostitusPostitatud: Esm. Veeb. 21, 2011 2:01 pm    Teema: M: Innovate LC-1 Wideband o2 With Db Blue/Red Gauge Vasta viitega
On müüa 1 sinine 1 punane komplekt, tuttuued.
The Innovate Motorsports DB gauges are 52mm (2 1/16”) air fuel gauges. Each gauge features a bright LED (available in blue or red), and retails for $229. Each kit includes the gauge, an LC-1 wideband controller, oxygen sensor & bung/plug, and the award-winning LogWorks engine-tuning software.
Key benefits of the “DB” kits include:
The industry’s most accurate and fastest-responding wideband controller.
One additional available analog output (one connects to the gauge).
Easy set up and wiring (instructions included).
LC-1 incIudes Innovate serial in & out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial).
“Blackout” appearance when unpowered.
Log directly from the LC-1’s digital output into laptop w/included software:
For tuners seeking the most cost-effective way to start monitoring Air/Fuel Ratio, the DB series gauges offer an attractive option, while opening the world of true digital data acquisition and software engine analysis. For example, users can add multi-sensor interfaces (starting as low as $129), and log 5 critical parameters directly into any PC or laptop. Or they can get a DL-32 data logger for hundreds of hours of 32-channel data logging on an SD card. Best of all, the DB gauges include the powerful LogWorks software for synchronous high-speed logging of wideband data, other MTS sensors, and data from a growing list of “piggyback” fuel controllers and standalone or factory (OBD2) ECUs. This is the same software used by champion engine builders and racers.
Asuvad Viljandis ja saadab üle eesti vajadusel.. Tallinnasse saab tuttav tuua.
53739192 voi maikmadi at gmail.com
Hinne on 200 eur
ptui, venna acciga kogemata tegin kuulutuse, Maik muidu müüa ikka :P
Uus teema   Vasta teemale    Car Club Viljandi -> Sõidukid/varuosad Kõik ajad on GMT + 3 Tundi
