M:2 võimu ja sub alghind 0,15 eur
Uus teema   Vasta teemale    Car Club Viljandi -> Audio
Focun
PostitusPostitatud: Teis. Veeb. 15, 2011 1:10 am    Teema: M:2 võimu ja sub alghind 0,15 eur Vasta viitega
Müüa 4 kanaliga võimendi Osio HPA 1400, võimendi sillatav, kaitse 10a, paras panna tavakõlaritele. siis 2 võiendi
US Blaster 3370 link ja andmed netist http://www.usblaster.com/index.php/9,hi ... artId--214
Power RMS 2 4x200W
Power RMS 4 2x100W
Power bridged 2 RMS 2x 400W
Input sensitivity 200mV - 4V
Technology Mosfet Power
S/N ratio 100dB
Frequency range 20Hz - 20kHz
THD <
Channel separation 60dB
2 stable Yes
Damping factor 100
Low pass filter 30 - 300Hz
High pass filter 30 - 300Hz
Dimensions 237x68x335mm
High-End
These amplifiers, designed in the USA, leave other amplifiers way behind in this price category. They feature power supplies incorporating pulse wave modulation (PWM) to ensure that this series produces an unparalleled sound. Other features include built-in adjustable high-pass and low-pass filters and a bass boost (+18dB). Exacting build quality includes complete protection and are fitted with high quality 24k gold-plated terminals. The 5-channel model, 201.348 (USB 3480) has a remote control unit allowing adjustment of the bass frequencies.
PWM Mos- fet power supply
Fully complimentary output stage
High current bussbar
REMOTE bass control (USB 3480)
Low and high pass built-in crossover (with defeat) 30 to 600 Hz. 12 dB per octave
Overload and thermal protection
Input sensitivity control ( adjustable )
separate front and rear adjustable sensitivity controls
Soft turn on and 0ff
24 Kt gold terminals and RCA jacks
Separate LEDS for power-on and protection
isolation mounting grommet
Sub Star Sound 12" kast tehtud audi B4 avandile , rohkem infot lehel http://www.hificar.cz/zesilovac/index.p ... &than=4265 ja sub Star sound 12" sub Tehnilised andmed
Single Voice Coil Subwoofer 12", 250W RMS, 4 oomi. Sagedusvahemik 30Hz - 900Hz, tundlikkus 88db. Kroomitud korpus, kullatud kontaktid.
T/S parameetrid:
Reve (DC VC Res) 3,3Ohm
Fs (Res Freq) 36,2896Hz
Zo (Z max at Fo) 29,5582Ohm
Sd (piston Area) 0,0491Sqm
BL (Flux*Lenght) 12,8889Tm
no (Ref Effency) 0,3854%
SPL (SPL at 1w/1m) 87,8874db
QMS (Mech Q) 4,7572
QES (Elec Q) 0,5979
QTS (Total Q) 0,5311
VAS (Acoustic Vol) 49,8600Litr.
Cms (Compliance) 145,7189Um/n
Mms (Total Mass) 131,9955Gram
Mmd (Diaphm Mass) 125,7420Gram
Kõlar olnud kasutuses umb 1,5 a võim 2-2,5 a , nüüd seisnud juba pikalt ehk läheb kellelgi vaja
Asjad osta.ee oksjonil ja asuvad Viljandimaal tel 53594603 võta osa oksjonist https://www.osta.ee/17197246
unistused pildil
fm25
PostitusPostitatud: Teis. Veeb. 15, 2011 10:35 am    Teema: Re: M:2 võimu ja sub alghind 0,15 eur Vasta viitega
pole osta.ee-s kontot ja pakun siis siin 10.-
AUTO on eluks vägagi vajalik
Focun
PostitusPostitatud: Kolm. Veeb. 16, 2011 12:09 am    Teema: Vasta viitega
50 on juba pakutud
unistused pildil
Uus teema   Vasta teemale    Car Club Viljandi -> Audio Kõik ajad on GMT + 3 Tundi
